Char-Lynn Pwr Steering on M
Don LC
03-21-2007 20:33:17
I bought a '51 Farmall M with Char-Lynn power steering with the unit installed up by the throtel lever and light bar....I would iike to move it down under the hood behind the duages..... .Does any body have a copy of instructions for installing this unit on a M..... I sure would like to have a copy,showing the extra pieces involved and instructions..... .thanks
Don L C
03-22-2007 09:13:16
 Re: Char-Lynn Pwr Steering on M in reply to Don LC, 03-21-2007 20:33:17
Is the Behlen a good unit?..... ..... Don
Don L C
03-22-2007 09:10:14
It could be a Beheln, I cant see any name....thanks.....
GordoSD
03-22-2007 05:25:18
I have the same problem with my SMTA. It is in fact a CharLyn. I have the new steering shafts made. Can I just bolt the control valve to the existing gauge plate with a little drilling, or does the "kit" come with a special heavy duty mount plate?
Gordo
GordoSD
03-22-2007 06:32:08
 Re: Char-Lynn Pwr Steering on M in reply to GordoSD, 03-22-2007 05:25:18
I liked the part in the instructions where it says to lower the hood on the installed unit, mark the places where the hood interferes, and "form" the hood with a ball peen hammer!
Gordo
Bob M
03-22-2007 07:09:02
 Re: Char-Lynn Pwr Steering on M in reply to GordoSD, 03-22-2007 06:32:08
The installer followed the Charlynn directions exactly when the kit was installed on my Super M! (The hood was indeed beaten out slightly from the inside to make room for the steering motor.)
Fortunately this "body work" is not noticeable unless you are right on top of it.
Bob M
03-22-2007 05:49:48
Gordo - The kit included a special bracket to support the steering motor and gages. However I don't see why the existing gage bracket cannot be cut/drilled as required to do the job.
Bob M
03-22-2007 04:47:13
Punch below. These were scanned from original Charlynn instructions supplied with the PS kit installed on my tractor in the late 60's.
georgeky
03-21-2007 21:51:51
Don are you sure it is Char-Lynn the only ones I have seen there have Behlen as they will not fit under hood. If it is Char-Lynn you should have every thing there for the move. I am sure someone will post a pic for you. I don't have one which is just as well since I can't post pics yet.
City-Boy McCoy
03-22-2007 02:33:49
 Re: Char-Lynn Pwr Steering on M in reply to georgeky, 03-21-2007 21:51:51
George: By his description, it surely does sound like he has a Behlen unit. If so, I don't think they can be moved. mike
georgeky
03-22-2007 06:18:58
 Re: Char-Lynn Pwr Steering on M in reply to City-Boy McCoy, 03-22-2007 02:33:49
I know, that is why I said It wouldn't fit under hood.
City-Boy McCoy
03-22-2007 09:27:33
 Re: Char-Lynn Pwr Steering on M in reply to georgeky, 03-22-2007 06:18:58
Yes, I was agreeing with you. mike
