First Year Fast Hitch as an Option
Retcol
02-22-2007 23:49:48
What year did IH first make fast hitch as an option and on which tractors? I have seen a fast hitch on a 1951 Super C but I know that had to be retrofitted. Did the SMTA have it as an option because I have seen a SMTA that had a fast hitch off of a 560.
Jim Becker
02-23-2007 18:05:56
 Re: First Year Fast Hitch as an Option in reply to Retcol, 02-22-2007 23:49:48
Fast-Hitch on the Super C was first demonstrated to dealers at Hinsdale in July 1953. At the time, IH stated that all older Super C and C tractors could be converted to Fast-Hitch.
gab
02-23-2007 15:23:34
1953 Super C was the first year as an option although I've got a instruction manual around here somewhere that shows two or three different kits according to the tractor serial # to be installed on earlier tractors. Jim
georgeky
02-23-2007 07:05:01
I am almost certain they came out in 1953. They were not offered on MTA, but could be fitted with one
T_Bone
02-23-2007 05:44:03
According to my book, factory fast hitch was available starting with serial No100001 which would make the SC a 1951.
I didn't see any "factory" fast hitch option listed for the "C", but like Hugh said I bet a bunch of add on's were installed latter.
T_Bone
CNKS
02-23-2007 17:34:05
 Re: First Year Fast Hitch as an Option in reply to T_Bone, 02-23-2007 05:44:03
I don't remember when it became available on the Super C, but it wasn't 100001, as that was the first SC produced, and they were not available until later.
Hugh MacKay
02-23-2007 03:16:48
Retcol: The fast hitch on Super C was a factory option not a retrofit. It first came in 52 or 53, definitely not 54. I remember seeing a Super C in a dealer display at a fall fair with 5 implements, however I'm not certain whether it was 52 or 53. The implements were; 2 bottom plow, 7' sickle mower, 24 blade tandem disk, platform carries and a tool bar carrier for either planting units or cultivator shanks. The problem here is all Super C right back to 51 could be fitted with that hitch and many were. The day I saw it would have been late Sept., and since it was a factory option, fresh out, I lean towards 1952. My reasoning, there are just too many around to have come out in fall of 53, and only have 15 months until 200 came along. For that reason, I have to say 1952, but not positive. The question, just how many dealer add ons took place.
For the 300 and 400 it was an option from day one in 1954. No SMTA were fitted with 400 fast hitches. The first fast hitch that would bolt up was the 450 fast hitch, and there were dealer add ons of those, on SMTA.
The one point fast hitch for the offsets is a bit questionable. Most will agree it came first on the 100. There are folks around who claim they have Super A that came from factory with fast hitch. I suspect if there are, they will be Super A1 built in 1954, and there were only 1,957 of those ever built. The Super A1 was basically a 100 with SA sheet metal. Many Super A have had 100-130 fast hitches added. It's a direct bolt up with one exception, the lift assist spring. There is no provission on SA rockshaft arm for the spring.
IaGary
02-23-2007 02:06:16
Almost had to be either 53 or 54 on the Super C.
Then my 55 300 has it from the factory.
RAW in IA
02-23-2007 01:39:22
I am sure the Super C was the first, but don,t know th year it became available. Was never on the Super M from the factory, but i understand a few were installed by dealers after the 400 came out.
Allan In NE
02-23-2007 01:32:53
Dunno,
First one I ever saw came on a new 400.
Allan
