Re: Need help - Farmall 460 D won’t startt
rustred
04-15-2018 07:56:14
the fuel filters sit on a slant on the 282 engines. make sure you have the bleeders on the high side, to get all the air out. did you start the tractor before changing filters? good idea that way you are cranking a warm engine that will turn faster ,plus eliminate wondering about pump problem. you can crack injection lines and pull it. saves a lot of cranking and battery.
