Track frames and rollers are off! Sigh.
135 Fan
04-13-2008 16:45:11
I used a long snipe (6 ft.) and got the bolts for the track frames to turn just a touch. Then the 3/4 electric impact took them out. Put the frames upside down and wacked the bolts pretty hard a few times. Of 40 bolts 10 broke. Only 3 on the second track frame. Didn't heat any though but the ones that broke were pretty rusty. Some had no rust. Kind of odd. I'm going to weld a nut or something on the broken ones. That usually makes them turn out easy. Pretty deep threads in the track frame. Quenching red hot steel can weaken it and/or cause hard spots. It all depends on the temperature. If it's above the critical temperature can weaken the steel. I think it's around 1600 deg. Drilling rigs often need some straightening using heat and quenching and sometimes heavy weights applied. I worked at a place that had a 4000 lb. sand bag they used for straightening. I discovered the idler yokes just pull right out with no disassembly required. If the roller bolts had been say 5/8 instead of 1/2 inch, I think I might have got them all out. 1/2 inch seems kind of small to me for something that will have to come out eventually. The track frames didn't fall right off because there are a couple of locating dowels on the brackets they bolt up to. I pounded a big chisel between the inner part of the track frame and the cross member and could see it start to come apart. Then I lowered the machine to ground and back up a couple times, and they finally came off. No rust on the locating pins, just a tight fit. Hopefully it goes back together a little easier with new hardware and everything cleaned up. Thanks to all who gave me advice. Now can just throw me some money for the new tracks? LoL. Dave
U9 U9 Cat
04-17-2008 07:50:32
 Re: Track frames and rollers are off! Sigh. in reply to 135 Fan, 04-13-2008 16:45:11
Way to go
