Continental F140 needs more grunt.
240 jockey
09-24-2006 16:36:36
I have a TerraTrac GT-34 with a tired Continental F140 although it is supposed to have an F162. Since the blocks are the same can I just bore out the F140 for the larger F162 pistons? What else can I do to give the old girl more power? If it was an OHV I would mill the head for more compression but that won't work on a flathead. Can I add larger valves and open up the ports? Any other ideas?
J Schwiebert
09-24-2006 17:29:09
 Re: Continental F140 needs more grunt. in reply to 240 jockey, 09-24-2006 16:36:36
Get the block sonic tested to be sure but you should be O. K. The 163 and 227 engines can not be bored that much. There were smal and large valve models. I take it you have not had this thing apart yet. Maybe making it a 162 will surprise you on the horse power end. J.
