450 j.d. weight
16al2
03-04-2006 14:18:05
need to haul my strait 450 and backhoe, no rops anyone know what this might weigh?
R-cubed
03-05-2006 13:13:50
 Re: 450 j.d. weight in reply to 16al2, 03-04-2006 14:18:05
The 9300 backhoe alone weighs 3400#
DGH
03-04-2006 21:38:50
20,000 to 21000 depending on what counter weights it has. There could be three, one on each sprocket and one under the drawbar.
Mark/ca
03-04-2006 21:12:39
My 450C loader 4/1, w/ hoe on it is right about 18000 LBS.
dave2pa
03-04-2006 15:32:01
hello I had a 450 loader long ago I think it went about 8 tons by itself so with hoe i bet you looking at 9 to 10 tons ,, Loaders are alot heavier then dozers
16al2
03-04-2006 14:56:32
i forgot to say it does have a loader, thanks
the tractor vet
03-04-2006 14:39:01
I am not real sure on one with a hoe on it but the 450C that i had had the 6 way blade with a rops with brush sweeps and a winch and it was all that ya wanted on a tri axel trailer behind a 3/4 ton as i am thinking that it went around 14-16000 and a hoe would push it close to 18000. . I hauled a 450 case with a backhoe for a neighbor farmer and it was more then enough on my tandem dual goose neck even bowed the loading ramp. And a Deere is heavier then a case.
