what is a 440 JD Dozer worth?
allen e. seals
02-06-2006 11:18:42
I have a real clean JD 440 Dozer, has 6way blade, motor has a pretty recent overhaul, the steering clutches and brakes have been all gone over. Has roll cage, needs nothing. How much is a little dozer like this selling for today?
parrothead
02-09-2006 07:10:26
 Re: what is a 440 JD Dozer worth? in reply to allen e. seals, 02-06-2006 11:18:42
I dunno, but dad and I have a 440 dozer, a 40C w/ JD ind. loader and rippers and a 40C dozer for sale. All 3 for $10,500.
TimBinWV
02-06-2006 16:46:38
It depends on what engine is in it,Detroit diesel or the gas 2cyl? Reverser? What's the undercarriage like? What's the location? 10k is somewhat optimistic for this part of the world.
That machine would bring around 5/6 thou here,if it's in good shape.7 if you found someone wanting it bad enough.
J.C. IN AZ.
02-06-2006 12:05:37
If as good as you say I would guess up or down a little from $10K wouild be realistic. They were good little Crawlers and still are according to your prospect. $10k is a down payment "Maybe" on such a machine now. Check the Track Rollers real close before you decide...[$10k-$10,000.00]
allen e. seals
02-06-2006 16:53:38
 Re: what is a 440 JD Dozer worth? in reply to J.C. IN AZ., 02-06-2006 12:05:37
The rollers are in good shape, it is a 2cylinder. It has a reverser
BKahler
02-06-2006 19:50:18
 Re: what is a 440 JD Dozer worth? in reply to allen e. seals, 02-06-2006 16:53:38
Allen,
Below is a list of 440 crawlers that have sold on ebay in the last year. I bought one and then wanted to know what they were really selling for so I started saving all of the auctions involving 440 crawlers. Some people consider ebay to be a good indication of what something is worth, others don't feel that way. Please forgive the text formating, I copied it from a speadsheet and just tried to clean it up a little.
Hope this helps you decide what yours is worth.
Brad
JD440IC $2,900 Runs ok Bad bearing in tranny Loader
JD440ICD $3,100 Decent condition reserve Not met $4750 Loader New York
JD440IC $1,800 Not running Dozer Ohio
JD440 $4,350 Reasonable condition Dozer Missouri
JD440ICD $1,427 Not running Dozer Arkansas
JD440 $1,026 Not running rough condition Dozer Michigan
JD440IC $4,037 Runs good reserve not met $4800 Dozer New York
JD440ICD $3,850 Good running lots of spares Dozer New York
JD440ICD $4,050 Good running Georgia
JD440IC $2,075 Siezed engine Loader Ohio
JD440IC $6,259 Rebuilt engine most everything rebuilt Dozer Oregon
JD440ICD $2,125 Runs good bad reverser Loader Pennsylvania
JD440ICD $4,490 Sticking injector reverser needs adjusting Loader/Backhoe Texas
JD440ICD $5,300 Runs good 80% undercarriage Loader Pennsylvania
JD440IC $2,800 Runs good reserve not met Dozer Pennsylvania
JD440ICD $1,500 Antifreeze in oil Dozer Arkansas
JD440 $4,154 Good running new under carriage Dozer 7' manual blade Pennsylvania
JD440IC $4,250 Good running with trailer, bad gauges Loader New Hampshire
JD440IC $3,607 Good running good under carriage No attachments Minnesota
JD440IC $2,425 Runs & drives, smokes Under carriage needs work Loader Pennsylvania
JD440IC $1,000 Dismantled but complete Blade fair tracks are poor Dozer Ohio
JD440ICD $3,150 Runs good Bad steering clutches Loader with ripper Ohio
JD440 $1,500 Parts only, no reverser, good pads Good engine Loader New York
JD440IC $2,803 Water in oil but runs flakey starter Loader PA
JD440ICD $2,950 Very good condition minor steering clutch issues Loader Rhode Island
JD440ICD $5,100 Good running, 5-speed needs starting fluid, good carriage Loader Texas
JD440IC $3,949 Good condition, 5-speed some welding on loader, good hyd Loader Minnesota
JD440ICD $4,455 Rebuilt engine, new steering clutches slow bleed down, adjuster needs work Loader Indiana
JD440IC $3,250 Good shape, good under carriage mostly rebuilt, couple of minor problems
Dozer 6 way blade Connecticut
JD440ICD $2,605 Good condition with reverser 50% under carriage, one track slips some Loader Wisconson
