Case 580B Info needed
52RM
03-17-2005 15:58:01
Hello,
I now own a Case 580B backhoe ,Could anybody tell me what transmission set up I have ?
It has a lever next to the steering wheel for fwd/rev..And a 4 speed trans,WITH another shifter in front of that,It also has a gas pedel on the right..The tractor needs a ring and pinon ,So I cant drive the tractor to see what these levers do..Any other info on this 580b you could tell me would be helpful....
I Thank You for your time !!
Al. Thanks
Marker
03-21-2005 11:40:36
 Re: Case 580B Info needed in reply to 52RM, 03-17-2005 15:58:01
Sounds like a shuttle transmission, with a high/low range. I've got a 580B w/shuttle trans, no hi/lo. I've got the shop manual, so I can answer more specific questions if you need.
Tim
RJC
03-20-2005 08:28:45
we have a 580b with power shuttle. They also made one with mechanical shuttle. Ours only has the one gear shift lever in the floor. I think we have some books at work, I will look at. Does anyone have any fixes other than new parts to tighten up the steering arms to the spindles? Got one really loose.
