D6H LGP
2x4
10-31-2004 21:38:54
What does it mean when the big light flashes red at the top of the instrument panel & the twin lightening marks flash red when starting. I have'nt found a book yet. doesn't seem to be important but its scary.
Bob/Ont
11-01-2004 05:33:00
 Re: D6H LGP in reply to 2x4, 10-31-2004 21:38:54
Lightning mark is "alt charging" and should go out when the engine starts. The big light is to draw your attention to the pannel.
Later Bob
2x4
11-01-2004 21:53:30
 Re: D6H LGP in reply to Bob/Ont, 11-01-2004 05:33:00
Thanks, relieves my mind a lot. Figured it was something like that.
Bob/Ont
11-02-2004 03:29:59
 Re: D6H LGP in reply to 2x4, 11-01-2004 21:53:30
The small wire with a cap that pushes onto the pin on the alt carrys a 12v pulse to the computer to keep that light off.
Later Bob
M7
12-29-2004 12:40:28
 Re: D6H LGP in reply to Bob/Ont, 11-02-2004 03:29:59
The terminal on the ALT is actually the "R" terminal and it creates an A/C current that signals the EMS in case of a low current conditon. There is no computer on this era of tractor. The big light in the middle is the fault light which is the second stage warning. The warnings are as followed LED warning on the EMS, Fault light, Action alarm. When you turn your key on you should have a lightning bolt and an oil press light flashing. With no action alarm. If your action alarm is going off you have another problem. Any questions feel free to ask me have more than 60000 hrs around these models and are a very good machine
PD Mechanical
11-01-2004 04:10:50
third party image
We have manuals available for your machine. Would need your serial # in order to get you correct manuals. If interested email me directly.
2x4
11-01-2004 22:06:42
 Re: D6H LGP in reply to PD Mechanical, 11-01-2004 04:10:50
tried to access your technical info but it says 504 failed, page maybe removed, so I emailed you.
