350B won't start
350B won't star
01-11-2004 17:34:55
I am rebuilding my final. I pulled her in the barn when it was a bit warmer. I cannot get her to kick. The temp is around 5', But I have never had a problem in the cold W/ starting fluid. I checked the fuel lines and fuel is flowing good. My start button is not working now?, I am jumping the starter to get her to kick. The motor will start on fluid but will not run. Will a faulty key switch cause this? Or push button?
Pete/ME
01-12-2004 02:46:09
 Re: 350B won't start in reply to 350B won't start, 01-11-2004 17:34:55
Went through my straight 350 last fall, incl. new ignition switch. Sometimes works, sometimes...nothing. Reach behind the dash, wiggle wires--sometimes works, sometimes nothing. Come back five minutes later and it starts fine. Got to be a bad connection somewhere. When it quits completely I'll re-wire the whole thing, can't be too expensive.
jdemaris
01-12-2004 05:56:28
 Re: Re: 350B won't start in reply to Pete/ME, 01-12-2004 02:46:09
As I said in the other post, the main harness plug often comes loose in the 350 series. It's just under the hood by the end that's by the dashboard.
jdemaris
01-11-2004 18:51:56
Maybe the main wire-harness connector under you hood has a bad connection. If it's loose, the injection pump won't get power (and it won't start) and your push-button for the starter motor won't work either.
