T6 dozer
John
05-07-2002 10:05:55
Saw a T6 for sale that is both gas and diesel. Can anyone bring me up to speed on this animal?
wheatland47
05-09-2002 19:52:39
 Re: T6 dozer in reply to John , 05-07-2002 10:05:55
If you don't want to rebuild the engine, see if you can find a MD and swap them...I believe the TD-6 motor and the MD motor are the same.
Lavoy
05-07-2002 18:50:13
TD6 starts on gas, then you switch it to diesel. The gas portion is for the most part non-throttling so it can not be used as both a gas and diesel.
Lavoy
Milton
05-07-2002 11:21:34
John, ----- ---- 7 / May / 2002 ----- -
What we need is the SERIAL NUMBER and PREFIX LETTERS of your crawler / so that we can see if it's a T-6 or a TD-6 crawler. T-6 is TBK and the
TD-6 is TDBK. Regards, Milton
clark
05-08-2002 18:35:37
 Re: Re: T6 dozer in reply to Milton , 05-07-2002 11:21:34
Just bought 2 TD-6 dozers, one was running but only on 2 cylinders its a 1954 model, the other one is a 1940 and has been setting so long the right track chain rusted off.. got it to run but it only will pop on diesel on 1 cylinder.. the 54 model is the one i want to restore, took the head off and found evidence of it being froze(rusted) up some time , the head was cracked on each cylinder between the valves..YUCK!! took the 1940 model head off and it looks to be in good condition except for the valves need replaceing and seats need to be fixed up..tryed to get the injector precombustion chambers out of both heads and they are rusted in solid, any tricks to getting these out??!! the international start on gas & run on diesel was designed warm the engine up on gas so it will fire up on diesel( low compression eng) without useing starting fluid, that reminds me, the preveious owner could never get the 54 to start on gas so they used starting fluid to get it to run on diesel, the head has pieces of metal blown out everywhere and the same for the pistons.. will be parting out the 1940 model, i wont be useing the blade so its forsale, with everything to mount and also everything for the hydraulics..its a bucyrus erie blade and in good condition also its a manule angle..the 1940 also has a big wench on the back may want to sell it too,, so if anyone wants the blade or wants to talk TD-6 crawlers id be happy to..
Brad In WA
11-05-2004 19:46:48
 Re: Re: Re: T6 dozer in reply to clark, 05-08-2002 18:35:37
Hi, What happened to the For Sale stuff? Tell me more about the stuff you have. I just acquired one yesterday. I'd like to know more. Thanks in advance. Brad
SHAD
10-07-2004 16:17:43
I have reciently aquired a 194? international bull grader. The serial # is 31708 modle TDR7733T4 this is a ex muilitary tractor. I am looking for parts to restore and use this 38k lb tractor on a weekly bases. This tractor has a 12ft blade. If any one has alteast a idea where I can go to find parts for such a crawler i would greatly appreciate it.
Mike
05-14-2002 13:18:50
Clark, where are you located? I have just purchased a TD6, and might need some parts.
Carrie
09-30-2004 18:43:14
 Re: Re: Re: Re: T6 dozer in reply to Mike, 05-14-2002 13:18:50
hi my friend just bought a TD6 we are trying to find out what year it is the #TDBK36367 if you have any idea or where i can find out hte info please email me. Thank You Carrie
kevin wa
09-22-2004 02:21:47
i can use the ring gear or the flywheel teeth are missing on the one of mine
Brad in WA
11-05-2004 19:50:35
 Re: Re: Re: Re: T6 dozer in reply to kevin wa, 09-22-2004 02:21:47
Hi, Do you still have the TD 6? How did you solve the missing teeth thing? Thanks in advance
Brad in Wenatchee
