OC 46-3g
negotiator
04-02-2013 18:45:43
I just picked up an Oliver Mod. 46-3g ser.# 2878 with the 3 cyl. Hercules engine ser.# 3751648. I'm wondering what year it was made and what the tuneup specs are (timing, point & plug gap, valve lash,ect). Any suggestions on uses for this machine besides pulling trees out of my woods?
LOU from Wi.
04-02-2013 19:40:27
 Re: OC 46-3g in reply to negotiator, 04-02-2013 18:45:43
negotiator,
PLUG GAP 0.24 Autolite 86 type
New parts for cross ref
Points BWD A40V
CONDENSOR BWD6102A
COIL MPIE30
RESISTOR MPI RU4
DIST CAP BWD C16
ROTOR BWD 010
Ignition timing @1700 rpm (btdc) 29deg.
Point gap .018- .020
Valve tappet clearence --exhaust .010
Valve tappet clearence--- intake .010
Firing order 1-3-2
Hyd System cap 10 Gal.
132 to 32F SAE20
32F to 0 SAE 10
0 to -35F SAE 10W-30
Engine oil 5 qt cap (plus 3/4 qt for filter)
Wix oil filter 51050
Transmission & Differential cap 7 U.S. quarts SAE 50 Use only a GL-1 Rating
Final Drive 2 1/2 pt per housing
32F or above SAE 140
32 to 0F SAE 90 or SAE 50 engine oil
Below 0 use SAE 10W 30
Hope it helps,
LOU
negotiator
04-02-2013 20:03:11
 Re: OC 46-3g in reply to LOU from Wi., 04-02-2013 19:40:27
You"re a saint Lou, thanks so much! negotiator
