580 ck b fluids
joe francano
11-06-2005 12:55:19
Hello,
I have an old 580 ck "b". It has a diesel engine. I change the oil and air oiler twice a year. I use the tractor and hoe about fifteen times a year. Nothing extreme. I also change the filters (hydraulic and fuel) twice a year also.
I guess I should change the shuttle fluid (transmission) and the differential fluid this fall.
I forget which one gets what type of fluid. It has been four of five years since I changed it.
Thanks.
Roger (Mi)
11-06-2005 19:34:41
 Re: 580B types of oil in reply to joe francano, 11-06-2005 12:55:19
Shuttle: TCH or its equivlent.
Rearend: 90W gear lube.
joe francano
11-08-2005 19:16:38
 Re: 580B types of oil in reply to Roger (Mi), 11-06-2005 19:34:41
Are TCH and R&O the same type of fluid?
Thanks.
Roger (Mi)
11-09-2005 16:01:31
 Re: Look for cross reference tables in reply to joe francano, 11-08-2005 19:16:38
Joe,
I'm not sure about R&O oil. If it has a table on the container stating that it's equvalent to TCH (Torque Converter Hydraulic) for J.I. Case, you're good to go. Good luck.
