David Brown 990 Wiring diagram
Ronnie Thomas
09-06-2004 16:56:19
I am looking for a wiring diagram for wires that go from the switch to the starter on a David Brown model 990, 1974ish model. Any help with this would be great. Just replaced the starter due to it staying engaged, and now need to replace the starter swith due to this burning up.
Case Miner
09-24-2006 16:03:38
 40's CASE VC in reply to
ritchie leslie
10-05-2004 11:33:23
 Re: David Brown 990 Wiring diagram in reply to Ronnie Thomas, 09-06-2004 16:56:19
Ronnie
I will need your email! I can't get hold of you to send the diagram.
RL
ritchie leslie
09-10-2004 09:49:31
I have the wiring diagram from the original operator's model if that would be helpful. Let me know.
Ronnie Thomas
09-13-2004 12:49:55
 Re: David Brown 990 Wiring diagram in reply to ritchie leslie, 09-10-2004 09:49:31
Ritchie; That would be great if you could e-mail me that. If it cannot be e-mailed then I can provide you a fax number.
ritchie leslie
09-14-2004 07:19:55
 Re: David Brown 990 Wiring diagram in reply to Ronnie Thomas, 09-13-2004 12:49:55
Send me your address direct to my email and I will send you a clean copy or fax as you prefer.
I won't be able to do this until next week as the manual is at my country place. I would also suggest replacement of the voltage regulator at the same time as it is buried under the dash and it's a pain to take the whole thing off. I managed to do similar electrical work without the need to remove the steering wheel or the tach drive cable.
Cheers
