Case 580 Super E Backhoe Transmission fluid ?
LumbrJakMan
08-31-2004 05:44:24
I am low in Transmission Fluid in my newly acquired 580 . Can I use any kind of Transmission Fluid , or does it have to be a certain type ?? Thanks ...
Terrance
09-01-2004 18:24:18
 Re: Case 580 Super E Backhoe Transmission fluid ? in reply to LumbrJakMan, 08-31-2004 05:44:24
The Case Manual calls for Case TCH Fluid, in the power shuttle 8 qts, master cylinders, and the hydraulic system 24 gal. Most major brands of Tractor Hydraulic Oil are suitable replacements for Case TCH Fluid. The Transaxle(4speed transmission/rear axle) 20 qts, transfer case(4x4) 1 pt, front drive axle(4x4)7 qts,and planetary 1.5 qt each, all use Case FDL fluid.
That is a great tractor take care of it and it will last a long time with little cost to you.
Hope this helps Terrance
just 580's
08-31-2004 19:26:05
Dextron II.
