Mike Schotte, My gas tank has rust in it!!
Dave
11-05-2003 07:46:34
Mike,
I see you said somthing about boiling out your gas tank.
Does this help with the rust, and do you just dump boiling water in, or throw the gas tank in a fire with water in it(haha)
Thanks in advance Mike
Dave
caseman-d
11-07-2003 18:15:38
 Re: Mike Schotte, My gas tank has rust in it!! in reply to Dave, 11-05-2003 07:46:34
Try red Kote, our carquest store handles the stuff. Runs about 16.00 for a quart.
caseman-d
David Bacon
11-05-2003 18:27:21
If you have another tractor with spoked wheels, duck tape your tank to the spoked wheel and throw some ---STEEL ----shot gun bb's into the tank and drive around for a while. Then power wash, rinse and treat it with a sealer. I do not use rocks or log chains etc. in the tank if it has baffles. If it has baffles in the tank you must use small items so they do not become lodged in behind the baffles. My sturdy wife likes the spoked wheels better than me having her shake the tank for a 8 hour day--bless her little heart. Dave NE Iowa
Bruce Wayne
11-05-2003 13:35:52
I have been sealing gas tanks for 30 years and have tried several products. POR-15 is the best I have found. $20 for a quart that will do a 25 gallon tank. Awesome stuff. Cover any holes with duct tape, pour POR 15 inside
F-I-T
11-05-2003 07:58:53
Dave:
If it's dirty or oily at all, clean it first with some alkaline cleaner, or a few tablespoons of lye and agitate, then blast with the powerwasher. I generally cork the bottom and let them sit full of lye water overnight, then powerwash.
If all you have is rust, you can try Phosphoric Acid (not Muriatic Acid!). It will convert the red rust to inert black oxide, but not hurt the steel, and let a nice rust-resistant phosphate coating behind. Throw in a short length of chain to help agitate, and then hit it with a powerwasher when through.
Frank
Mike Schotte
11-05-2003 07:51:44
I had mine dipped in the hot tank at a local radiator shop.
I think they charged me $25.00
-S.
Klyde
11-05-2003 17:28:03
 Re: Re: Mike Schotte, My gas tank has rust in it!! in reply to Mike Schotte, 11-05-2003 07:51:44
Well you did'nt say that----- torch away...
Craig
11-05-2003 13:26:04
Mike,
Can you provide info on where you bought the kit?
thanks,
Craig
Mike Schotte
11-05-2003 13:34:18
 Re: Re: Re: Mike Schotte, My gas tank has rust in in reply to Craig, 11-05-2003 13:26:04
Craig,
I can't answer your question- 'cause I haven't bought a sealer kit yet. If you look below- Dr.C said his version came from Eastwood.
Another brand is POR-15 (I think) and Kreem. I think those might be available at NAPA.
Good luck.
-S.
Dave
11-06-2003 05:58:15
 Re: Re: Re: Re: Mike Schotte, My gas tank has rust in reply to Mike Schotte, 11-05-2003 13:34:18
Craig,
I have used Kreem in a lawn tractor tank, It works, but I think it is starting to break down. That is why I am trying to figure out what to do with my case sc.
Dave
Oh, yeah...
11-05-2003 07:55:15
I forgot about the rust part-
The hot dip should remove most of the loose stuff and disolve any varnish, but to knock the rust off the inside of the tank- you can put small rocks or a piece of chain inside and tumble the tank around as an abrasive to clean the inside.
Keep washing with water until it runs out clear.
Then you can do one of those acid wash/tank sealer product thingamabobs for fuel tanks.
Dr. Cy Kosis just did the tank on his Case L, but I can't remember which product he used...
-Schotte
Dr Cy Kosis
11-05-2003 11:53:11
 Re: Re: Re: Mike Schotte, My gas tank has rust in in reply to Oh, yeah..., 11-05-2003 07:55:15
I used a gas tank sealing kit from Eastwood. It came with everything needed but muratic acid and acetone thats obtainable from any hardware store.
Its a very thorough process they use and can take all day but I was very pleased with the end results. My tank had 23 holes in it that I could see daylight through and it sealed them all. The only thing I'd add is that if you're doing a large tank, 15 galloons or more, I'd order an extra bottle of the 'Goo'. The basic kit was about $55 by the time you add shipping.
I'm about to clean and coat my C tank now and end my rust and seep problems with it forever too.
