PTO Clutch adjustment on 930 Case Comfort King
Derrek
08-27-2003 09:12:44
Hey guys. Hoping you can help me out. I just need to know where the adjustment nut is to adjust the PTO clutch on my Case 930 Comfort King.
Any help would be greatly appreciated.
Derrek
turbo
08-27-2003 10:13:56
 Re: PTO Clutch adjustment on 930 Case Comfort King in reply to Derrek, 08-27-2003 09:12:44
On the RH rear of the housing below the remote valve, there is a 5 or 6 inch round cover with three 3/8 bolts and usually a strap retaining the RH remote to coupler hoses. Remove cover and get a good light and you have to pull out and push the lock pins. You need the special tool with a slot in it or make one out of a screw driver. They go 1/2 click at a time so you have to alternate between the 2 pins.
Derrek Kyzar
09-10-2003 06:34:26
 Re: Re: PTO Clutch adjustment on 930 Case Comfort in reply to turbo, 08-27-2003 10:13:56
Hey Turbo.
My dad is the one that is working on it and is still having trouble. He was wondering if you happened to have a picture that you could fax, or would be willing to talk to him over the phone. If you wanted, you could email me a phone number that you could be reached after 6pm CST.
dkyzar@i-55.comnospam (take out the nospam) is my email address.
Let me know and thanks!
Derrek
bob
08-27-2003 19:01:33
better check if right or left hand threads as their are different ones believe 1030 is left biut not for sure
Derrek
08-27-2003 10:24:05
Thanks a ton, turbo.
Will let you know how that goes.
Derrek
