Re: adding oil to transmission on 880 DB ?
dick benson
09-22-2015 08:05:53
I appreciate it. Wasn't sure with two drain plugs and two fill plugs? Dick, OR.
ArleninOr
09-22-2015 11:29:56
 Re: adding oil to transmission on 880 DB ? in reply to dick benson, 09-22-2015 08:05:53
Good morning Dick. Just the one fill plug with 24 quarts of hy-tran. Looked at mine but the 2nd screw you are pointing at don't exist on mine. Go figure.
JTWAT
09-22-2015 14:02:34
 Re: adding oil to transmission on 880 DB ? in reply to ArleninOr, 09-22-2015 11:29:56
That PTO seal is available through NAPA. I just got one. I can give you the seal number is you need it. It was still $19.00 though.
dick benson
09-22-2015 17:59:10
 Re: adding oil to transmission on 880 DB ? in reply to JTWAT, 09-22-2015 14:02:34
Got the seal in, ($5.95) filled with oil. Thanks, Dick, OR.
