Case 2590-draining trans oil?
Tx Jim
02-25-2008 04:08:15
Where is the corect plug/plugs to drain trans/hyd oi in a 2590? The operators manual has a picture of a plug but I can't figure out exactly where it is. I did get the filters changed. BTW it's my neighbors tractor. Thanks,Jim
Tx Jim
02-26-2008 04:18:47
 Re: Case 2590-draining trans oil? in reply to 012grean, 02-25-2008 04:08:15
Thanks for replies,Jim
big orangea
02-25-2008 17:15:45
 Re: Case 2590-draining trans oil? in reply to Tx Jim, 02-25-2008 04:08:15
Two plugs in the filter housing, one either right in front of or behind the filter housing, and one directly above the drawbar, holds 30 gallon.
JoeBob/IN
02-25-2008 10:08:36
There are several all along the bottom of the rearend starting just behind the engine block to the actual rearend. May have to swing draw bar over to get one of them... can't remember for sure. Have plenty of 5 gallon buckets ready, holds something like 25 gallons!
