wd handclutch
ray in mn
05-04-2007 19:13:34
what do i need to do to replace the throwout bearing on a wd handclutch
Jeff McBride
05-04-2007 20:45:08
 Re: wd handclutch in reply to ray in mn, 05-04-2007 19:13:34
Best I can tell there is no throw out bearing on the hand clutch. There is a brass shifting collar. I am trying to change one right now for a 88 year old friend. What happened to his is the brass wore out and just slips on and off the mechanisim that ingages and disingages the clutch. Sorry for the bad spelling Kim needs to put a spell checker on the website ( just a bit of humer) Good luck with it.
Texas Denny
05-04-2007 20:38:12
IT manual says you have to break tractor in half at the transmission. If the shift collar is the problem, you can change that by removing the cover under the battery.
