wd plow
36 A
04-23-2006 19:54:48
WD tractor and WD PLOW the thing dose not trail straight. the tail goes twords th forrow.
parker up north
04-25-2006 05:09:13
 Re: wd plow in reply to 36 A, 04-23-2006 19:54:48
you need to make some drafting ajustments. is it a wide front? if so, you need to determine if the front tire in the furrow is set to wide, also is the rear set wide, the rear needs to be set at 14 to 16 inches depending on your plow size from the outside of the plow point and the front in aligned with the rear. the plow has drafting ajustments on it and the lift arms also ajust to make it draft proper. the plow setting on the ground on a flat surface hooked to the tractor should for the most part on the points tipped to the land side3 to 4 inches from plum
