1955 Allis Chalmers
richard in CP
02-21-2006 08:32:23
Can anyone tell me hoe the crank gets oil? The baring closest to the rad starved for oil and started knocking.
steve(ill)
02-21-2006 19:37:22
 Re: 1955 Allis Chalmers in reply to richard in CP, 02-21-2006 08:32:23
not sure which model youhave, but the B-C tractors have the pump in the back of the motor. pump pushes oil down a hollow cam shaft. cam bearings are lubed from that. main bearings get lube thru holes from the cam bearing areas. pressure lube to the mains. the piston pins and rod bearings on the crank are spray lubed. holes in the cam shaft spray everything while the cam is turning.--- there is alos pressureized oil to the top end and rocker shaft is hollow. oil goes down the shaft and lubes all 8 rocker arms as oil leaks out around the endges and down stems of valves.
