Gasket needed
36 A
01-31-2006 16:56:21
I went to the dealer to buy a gasket for the belt pully and they said you can"t buy it.It is the gasket that goes between the frame and the bell housing.What are other pople doing.Thanks
CA
01-31-2006 19:34:06
 Re: Gasket needed in reply to 36 A, 01-31-2006 16:56:21
GO TO A FARM TIRE SHOP GET A O-RING FOR A TUBELESS LOADER WHEEL 5/16 DIA. COST ABOUT 6.00
CUT TO SIZE PUT CUT AT TOP OF HOUSING. WORKS GREAT
Rod (NH)
01-31-2006 19:22:34
Hi,
How about making your own gasket? You can get sheet gasket stock in different thicknesses at NAPA. Both the gasket stock and a gasket punch set will probably cost no more than an "official" gasket through AGCO. I make my own that way all the time. It's a simple process and for hard-to-find or unavailable gaskets, it's the best way - IMO.
third party image Rod
36 A
01-31-2006 19:02:16
thanks again i"ll check the number out if not i"ll glue it.
Michael D.
01-31-2006 17:56:07
I just bought two of them from Sandy Lake Implement. I took it that they stock them as new stock the part number is 0070202289. They came in an AGCO package. The only thing I wasnt sure about is it was tough to get it in and I had to cut about a 1/4" piece out to make it fit right. Havent had any leaks yet and I have added lube to the housing where it all fits.
old
01-31-2006 17:10:38
When I put a pulley on my WC Speed patrol I used silicone, since I was told there where no gaskets to be had by the ARCO AG dealer.
