freeze cracked block on wd
36 A
01-01-2006 19:29:13
Can a block be welded or is it a boat ancor.How about the shifter it pulls out what is there to hold it in there.Thanks
36 A
01-02-2006 09:01:18
 Re: freeze cracked block on wd in reply to 36 A, 01-01-2006 19:29:13
Thanks guys i"ll have to look for the keys in the trany and stop at a machine shop for the screws.
JMS/MN
01-02-2006 16:24:35
 Re: freeze cracked block on wd in reply to 36 A, 01-02-2006 09:01:18
A WD has only one square-ended pin, the WD45 has two- so don't look for two if there is only one slot in the shift lever.
bw in mo
01-02-2006 04:23:31
If no pieces are missing it can be welded or stiched togather with small cast bolts. When finished can't tell where the crack was at, either way will be slow work.
farmered
01-02-2006 01:33:50
There should be a snap ring in the top of the tower to hold that wayward lever in place. When it comes out be careful not to loose the two keys down into the tranny! A new boot is a good investment to keep water out. Ed
