WD vs WD 45 pistons
playfarmer
05-05-2005 07:41:18
I was planning on putting a 45 crank in my WD but reacently was told that it wouldn't work unless I also change the pistons. Is this true?? It has the crater pistons in it now but a WD crank. The top of the pistons are around 1/2 inch from the top of the cylinder. I can see that if the crank has a 1/2 inch more throw that it would be too high but is there another way? (could I use the lathe to take off some of the top of the piston or is that foolish) Its getting pretty pricey to buy all the new stuff and the WD crank is ruined so I have to use the 45 crank to get it running.
Thanks
bw in mo
05-06-2005 17:27:54
 Re: WD vs WD 45 pistons in reply to playfarmer, 05-05-2005 07:41:18
I have several WC WD cranks that I would trade with you. I live in East centeral MO. 573-324-3693.
mackman
05-05-2005 09:39:11
It will work the piston only goes 1/4 inch higher at top of throw and a 1/4 inch lower at the bottom of throw. If you are using the same sleeves make sure you don"t have too much of a wear lip where the top ring used to stop or even carbon build up so that you don"t bust a ring when it goes past that spot with the new crank.
CA+
05-05-2005 08:17:10
YOU CAN USE 45 CRANK WITH THE WD PISTON. WILL GO ONLY UP 1/4" MORE IN THE BORE WILL UP COMP.
OR I HAVE A GOOD WD CRANK I WILL TRADE WITH YOU. CALL ME AT 828 256 8821 AFTER 6 PM I AM IN NC.
THANKS
