D19 Serial Number
R.J.
04-26-2004 17:36:19
Where is the serial number located on a D19?
There are a couple sets of numbers stamped on the engine, but I don't know what they are or what they mean.... 2-65-63 and 4512880 with a 7 under it.
Any ideas?
Dan
05-12-2004 21:51:28
 Re: D19 Serial Number in reply to R.J., 04-26-2004 17:36:19
The serial number will be stamped right behind the seat on top of the top plate of the main drive. If you stand behind the tractor the numbers will read left to right. I had to scrape the paint off to find mine. There also should be a serial number stamped on the engine oil dipstick. The serial number on the engine block is just for the engine.
Kevin (FL)
04-26-2004 20:21:57
It's supposed to be on the top of the rear main housing. I thought it would be the same as our D17, but I looked it up in Norm's book. Those numbers you found don't ring any bells, unless you could remove the 45, then you'd have 12880--a '63 model. Here's the range by year:
'61: 1001-1249
'62: 1250-7331
'63: 12001-14944
'64: 14945-16266
