head bolt torque spec
chad
02-13-2004 05:44:43
can someone give me the head bolt torque spec for a wd-45 and if you know the tighting pattern can you please give me the info?
thank
Chad
JMS/MN
02-13-2004 12:18:49
 Re: head bolt torque spec in reply to chad, 02-13-2004 05:44:43
The tightening sequence on a head is from the center to the ends, alternating side to side. Just picture pushing the pressure away from the center, rather than locking it in somewhere. Torque specs vary with the size of the bolt- there are some 3/8?, some 1/2?. It's in the I&T manual, the manual is in the shop, and I'm not, so I won't trust my memory. It's gbs. And how you determine torque on the water manifold bolts????? ????? I just substitute a combo wrench and compare it to the torqued ones.
guyzoo
02-14-2004 13:01:43
 Re: Re: head bolt torque spec in reply to JMS/MN, 02-13-2004 12:18:49
the 3 littles are torqued at 25 and the big are torqued at 80.
chad
02-16-2004 04:36:42
 Re: Re: Re: head bolt torque spec in reply to guyzoo, 02-14-2004 13:01:43
thanks for the help guys!
Chad
