WD subsoiler
37G
07-29-2003 17:45:44
Hello...anybody have photo or illistration or directions to hook up a subsoiler to my WD. It does not have the bell housing the earlier type that works with drawbar. To i have to disconnect drawbar or what?? thanks in advance!!
John Rogers
07-31-2003 19:39:28
 Re: WD subsoiler in reply to 37G, 07-29-2003 17:45:44
Hi, On a WD without Snap coupler you will need to remove the drawbar & possibly the drawbar bail if you can't pin it up high enough to avoid interference with the subsoiler tongue.The clevis that the front end of the drawbar was hooked to should be long enough to just drop the pin that was in the drawbar thru the eye on the subsoiler, if not just make a longer clevis. Of course you will need the latches that go on the lift arms. Just be sure you have a cotter key in the pin or preferably use a large bolt and nut as bad things happen when the tongue of a snap coupler implement comes uncoupled. John in Mo.
