Re: Is any part of this C a CA?
acken fromwisc
03-24-2015 15:39:44
serial number says a "C"
David R Inman
03-24-2015 16:03:38
 Re: Is any part of this C a CA? in reply to acken fromwisc, 03-24-2015 15:39:44
Yes, that tractor no is a C.
The clean large hole on the right is for the fill neck of the aux tank used with a Kerosene set up, the small holes for the bolts to hold said tank.
I don't know if the exhaust hole is in the exact same location on the C and CA (or if the C and CA hood is interchangeable) , but it is on the left side, and yours has been "farmer enlarged"
I find this link that might alos help to check the motor:
Okie65
03-25-2015 11:27:23
 Re: Is any part of this C a CA? in reply to David R Inman, 03-24-2015 16:03:38
Thanks a lot for the information, especially about that "farmer enlarged" hood modification. Looks like I'll just clean up that rough hole and use a through-hood muffler. Your information about the starter tank hole in the hood really put me in research mode. I never knew about the dual-fuel setup for starting on high-grade and switching to lower grade fuel after warming. Now I am in search of a tank to put up under those holes! They appear to be really hard to find in decent shape. I'll probably just make a simple repro if I don't find one in local tractor bone yards.
Bob Bancroft
03-25-2015 13:36:34
 Re: Is any part of this C a CA? in reply to Okie65, 03-25-2015 11:27:23
And no matter how old I get, I keep learning. That short, angled steering arm on your C had me baffled, as I had never seen one. So I looked it up at Agco parts. They show four possibilities!
