Re: delco generators
Posted by karl f on March 13, 2009 at 19:52:52 from (172.162.205.81):
In Reply to: Re: delco generators posted by glennster on March 13, 2009 at 15:48:29:
thanks glennster. Never realized there also were different body lengths. Assumed delco was delco, ford was ford, lucas was useless ;) and so on...
are those all delco generators in the picture?
I would bet the little pop can model has a low amperage output and is meant for no lights or accessories.
you should see the generator for an old Overland car. the "pulley end" is actually mounted to the engine block, has a gear attatched, and is driven by the timing gears. the other end houses the distributor! other fancy ones i've heard of in automotive have a power steering pump mounted on the back end.
i'll be measuring all the generators i find now.
karl f
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: John Deere 750 Diesel Yanmar J80TU engine. pistons and rings replaced when discovered crankshaft was bent. 3995 OBO Pictures available upon request [More Ads]
