Re: OT dodge charging problem
Posted by 806 Curt on March 17, 2015 at 19:41:33 from (206.126.211.30):
In Reply to: Re: OT dodge charging problem posted by Ron in can on March 17, 2015 at 11:19:39:
Here's what I would like you to try if you have a multimeter. Hook the batteries to the truck normally and start the truck. Next set your multimeter for voltage. Put one lead to one battery positive and put the other lead to the other battery positive. If your meter is showing more than 0.5 volts I would say you have a bad connection between the positives of the two batteries. If it shows less than 0.5 volts your positive side is ok. Next check the negative side. Put one lead from passenger side battery negative and the other lead to a good grounded area of the engine block or head. Once again should show 0.5 volts or less. Any more and you have a bad connection between that battery and ground. Do the same test for the other battery.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - 50 Tips for Ford N Owners - by Bruce Haynes. Over the years of owning these three tractors, I have managed to refresh what little mechanical knowledge I had and add a little more, thanks to the wisdom and helpfulness of many fellow N owners. So, now it's my turn to share a few of the tips I've picked up. ... [Read Article]
Latest Ad: Massey Ferguson model 65 diesel tractor [More Ads]
