Posted by Janicholson on March 15, 2015 at 19:07:19 from (63.152.241.241):
In Reply to: 656 gas engine oil posted by MNfarmer on March 15, 2015 at 17:30:44:
The following is an Email from Shell Oil to Me, followed by my original question to them.
Dear Sir,
The information we have for the Farmall 706 (gasoline) indicates it called for an API SF low ash oil (max 0.5% ) for viscosity ranges of 10w, 30w, and 5w-30. No information on higher viscosity ranges is listed in our reference. Rotella T 15w-40 meets API SM specifications for gasoline engines, which covers API SF, but has a maximum ash content of 1%.
Best Regards,
Shell Technical
On Wed, 10 Apr 2013 01:09:33 +0000 you wrote:
>I participate in a forum at Yesterdays Tractors. IH “Farmall” has specified >Low ash oil for use in its gasoline engines from the early 1960s. We are in a >discussion as to whether the current Low ash diesel grade oils are of the same >intended (or unintended) ash levels. My family has been a consistent user of >Rotella Oils, and would like to be assured that if we used 15- 40 Rotella >diesel oil in a 706 Farmall gasoline tractor, that it would meet the same low >ash intentions as the IH branded oil from the dealer. >Dr. James A Nicholson, Technology Department St. Cloud State University, >janicholson@stcloudstate.edu > >James A. Nicholson, Ph.D.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and
... [Read Article]
