Posted by Nebraska Kirk on March 09, 2015 at 20:22:20 from (207.91.4.159):
In Reply to: Tire sizes for FH rim posted by FarmallCT on March 09, 2015 at 18:14:55:
Old gave you good advice on what tire to use on the rear.
With regards to your question on front tires, when they were changed over to rubber tires, the front vertical steering shaft was lengthened on the bottom to raise the front up so that it would be level. If your Regular has had this done to the front already, then it will set close to level with 6.00x16 or 6.50x16 tires on it. If your tractor has NOT had the front raised by lengthening the vertical shaft, then you are SOL as 6.00x16 is about the largest tire that will fit. Much larger and it will rub on the frame.
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in.
... [Read Article]
Latest Ad:
[More Ads]
