Re: 301 valve timeing
Posted by David G on February 22, 2015 at 05:34:55 from (204.12.184.93):
In Reply to: Re: 301 valve timeing posted by ericsegaline on February 21, 2015 at 22:21:32:
Are the cam dots on two teeth that are next two each other, if so the crank dot goes between them.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
