Posted by Frontline1 on February 20, 2015 at 15:15:40 from (209.181.34.70):
In Reply to: 1086 drive issues - posted by The tractor vet on February 19, 2015 at 19:20:44:
I do not have power steering (no steering at all, actually, the wheel spins fairly freely and not even a wiggle on the front wheels). I don't know about the brakes, either, the wheels are cramped to the left and the loader bucket is on the ground, so I didn't do much other than put it in gear and slip the clutch a little to see if it would move, and it did - looks like pretty much everything is dead hydraulic-related, all she's got is mechanical. The clutch I'm not sure on, feels stiffer than a pickup - assuming power-assist there is out, too.
I've been in a 1486 FWA that stripped that spline, but that one sounded like the clutch was coming through the floor when you started it - this one is, surprisingly, fairly quiet, enough that you can hear a little bit of spring rattle from the disc when you step on the clutch. That's what was bothering me, it was a little too quiet to say absolutely that was the problem. I'm thinking that $2500 including the loader might be worth the gamble.....
Next question would be manuals - are the Blue Ribbon ones the best way to go?
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the
... [Read Article]
Latest Ad:
Late 50s early 60s international harvester 560 with cultivator
[More Ads]
