Re: 1086 drive issues -
Posted by Janicholson on February 20, 2015 at 07:54:51 from (199.17.6.37):
In Reply to: 1086 drive issues - posted by Frontline1 on February 19, 2015 at 16:58:35:
I go with the tractor Vet answer, there is a splined tube that operates the hydraulic pumps and IPTO. It splines into the clutch pressure plate bypassing the clutch action allowing "live" Hydro and PTO. When it strips, it requires a new tubular shaft, and clutch Pressure plate. (split) Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
