Re: CUB front crank haft seal
Posted by john *.?-!.* cub owner on January 05, 2015 at 18:25:47 from (75.121.57.128):
In Reply to: CUB front crank haft seal posted by courtland508 on January 05, 2015 at 05:06:14:
While it can be done with the cover in place, I strongly recommend removing it. The cover is pretty thin and has NO support in that area other than where it bolts to the oil pan.
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
