Re: CUB front crank haft seal
Posted by K-Mo on January 05, 2015 at 06:45:19 from (66.43.226.235):
In Reply to: CUB front crank haft seal posted by courtland508 on January 05, 2015 at 05:06:14:
Yes and No. Most likely no. But it depends on the previous installation of the front cover. When installing the front cover, it is important to install the front seal and crankshaft pulley before tightening it down. This centers the front cover on the crankshaft. If the front cover was properly installed it should be centered.
Seal. There are two parts numbers. One for the seal only and the other for seal and wear sleeve kit. Some after market sources use the kit part number for the seal only. If you need the kit with the wear sleeve, make sure you are getting the kit, not just the seal.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
