Re: 1066 Engine Problem
Posted by DeltaRed on December 10, 2014 at 07:57:35 from (65.100.146.140):
In Reply to: 1066 Engine Problem posted by Rich in Ont. on December 10, 2014 at 07:47:12:
Your turbo could be failing.Blowing oil out through the seals.Since you say the oil is getting thinner,your injection pump seal is leaking/failed. Does it smell like diesel? if so,pump fixing time.Do not run it like that! thinned oil is not sufficent engine protection.Engine failure can/will result.Refill with fresh oil,see if the noise goes away.Do a bit of trouble shooting before any rash decisions
  Upload Photo  Select Gallery Photo  Attach Serial No List
