The ring gear number 396421R1 should be correct. The Hydro tractor uses the same flywheel and ring gear for both gas and diesel.
The number you posted for the drive, 1877355, must be in error. That number comes up as a CW drive with a 36 mm gear rather than a 32 mm gear. A CW drive will not go on a CCW armature.
The diesel starter number should be 1113201. That starter used drive number 1970544. It has the physical dimensions as drive number 1851427 which is uses for the gasoline starter. It s also the drive used on later gas gear drive transmissions. The difference between the two drives is the diesel drive uses a spragg type clutch while the gas drive is a roller clutch.
Today's Featured Article - Restoration Story: 1929 McCormick-Deering 10-20 - by Randal Simmon. On July 4th 1998 my dad and I was sitting on the front porch when he said that he was going to sell his two 10-20's to a junk man. He said that the junk man was going to give him $500 for both of them but he hadn't received the money for them yet. So I went into the house and wrote him a check for $500 and bought them myself and said now they are mine. He had bought them about five years before thinking that he was going to restore them himself. After five years sitting in the barn, he changed h
... [Read Article]
Latest Ad:
1 SD Gibson, 1 D Model needs rear end assembled and installed, 1 D Model needs minor repairs, extra parts
[More Ads]
