Re: 1950 M starts misses till warm
Posted by Janicholson on November 16, 2014 at 10:40:36 from (74.60.94.18):
In Reply to: 1950 M starts misses till warm posted by Rod1555 on November 16, 2014 at 09:40:09:
Excessive valve stem clearance on that cylinder intake can cause enough vacuum leak to be a source of that kind of misfire. with it running and cold enough to have the misfire, use a insulated pliers to pull the spark plug wire loose from the #2 plug. Not off, just loose enough to form a 1/4" gap. if the engine takes off running, that plug if fouled swap it for one in a different cylinder and it might come back from the dead. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tractor Profile: Oliver 70 Row Crop - by Staff. The Oliver 70 was part of the "Fleetline Series" and was manufacturered from 1937 to 1948. The row-crop configuration could have either dual or single front wheels. The Oliver 70 was also offered in the standard, orchard and industrial configurations. The tractors were sold in Canada. An early advertisement states "Power when you want it - power when you need it - power to help put in crops when field conditions are right and time and help are limited. That's the power you'll find in an Oliv ... [Read Article]
