Re: IH 674 ? 2 reservoirs
Posted by jimb2 on November 07, 2014 at 14:25:22 from (99.241.118.87):
In Reply to: IH 674 ? 2 reservoirs posted by John Zitkus on November 07, 2014 at 07:47:51:
Hi John,
There are 2 chambers in a 674, see caseih.com
parts at:
http://partstore.caseih.com/us/parts-
search.html#epc::mr62746ar372034
There is a transfer pump that is supposed to
keep the hydraulic fluid level even in both
chambers. There is a plug, item #3 in the parts
diagram that can be pulled to allow hydraulic
fluid to flow between the chambers. Most IH
mechanics advise to over fill by 5 to 10
gallons of hydraulic fluid.
There is also a third drain plug under the
right rear axle. If you have a loader installed
the return line from the loader control valves
may go into this drain plug.
I hope the new pump fixes the problem and it is
not the PTO drive splines on the pressure plate
that are stripped.
Good luck
JimB
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Buying your first tractor: Choosing the right one - by Chris Pratt. They cost less than the tax on a new tractor (at least where we live). They have the weight to do the job. They are simple and understandable. They even have a history and can be restored to become a major source of pride and enjoyment. But how do you know what to buy and how do you make the right purchase? There is a surprising number of machines available in every shape and size imaginable. Like most things in life, your needs have a lot to do with wh ... [Read Article]
