Re: 656 Diesel fuel in crankcase oil
Posted by DeltaRed on October 06, 2014 at 06:57:40 from (67.40.59.72):
In Reply to: 656 Diesel fuel in crankcase oil posted by luv2wrench on October 06, 2014 at 06:50:49:
I assume it is a 282 with RoosaMaster pump.The pump drive seal has failed.Pull the pump and replace the seal.Since you are a 'diesel mechanic',you will have no problem with this 'minor' repair. Get a manual.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
