Re: Radiator flush
Posted by NNP on September 20, 2014 at 06:00:51 from (66.66.112.196):
In Reply to: Radiator flush posted by Senator on September 19, 2014 at 19:21:38:
your money, your choice.
I've successfully flushed some real nightmare cooling systems because the junk tractor wasn't worth spending money on.
But, it is not a 5 minute process.
Flush water first one way then the other, many times.
summertime, plain water and some vinegar or whatever, drive it around and then do it again.....and again.
block drains open, hoses removed, waterpumps off if applicable,
back and forth with the water under as much pressure/volume as possible.
(radiator much less of course)
even tapping on the block with a rubber hammer as the water is back flushing.
Takes forever, and pick a warm day, as you will get soaked.
But it will help.
ever see a fast moving stream? moving water will wear away solid rock if you give it enough time.
ps don't forget water pump passages and the inside of cast 'hoses'
sticking the high pressure end of your garden hose in a block drain hole will give you a bath but really belches out the muck. (have the hoses off when you do this, so it doesn't plug up other things.)
This post was edited by NNP at 06:11:08 09/20/14.
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming. ... [Read Article]
