Re: 1086 Hydraulic Pressure
Posted by Owen Aaland on September 03, 2014 at 16:07:24 from (216.47.34.49):
In Reply to: 1086 Hydraulic Pressure posted by PHOY on September 02, 2014 at 08:33:16:
I don't believe I've ever seen someone pull the TA without disconnecting the AC lines.
As long as the quick disconnect works simple close the suction side valve, run the AC a minute or so to evacuate the pump, remove the suction valve from the compressor with the hose attached. Position the hose with valve back with the cab and disconnect the high pressure line at eh cab.
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
