Posted by Janicholson on August 25, 2014 at 18:33:46 from (74.60.94.18):
In Reply to: h and m brakes posted by dewy on August 25, 2014 at 18:19:27:
The covers need to come off and the linkage lever is in the road and must be removed first. But they could be stuck in two gears at once, If so the gear lever is taken out and the shift rails moved to alignment in neutral. If the brakes were set and locked down when parked, that is probabl. Taking some ATF or Liquid Wrench/PB Blaster to the linkage and a brass hammer might get them loose as well. Jim
Today's Featured Article - Product Review: JB Weld - by Staff. JB Weld is basically an epoxy glue that does an exceptionally good job of bonding to cast iron and steel along with several other materials. As I mentioned, it is so common that I have yet to buy a tractor that did not have JB Weld used somewhere. It is sometimes used so well you can't tell its there and other times used as a sloppy quick fix. Finding where and how it can be used correctly is key to whether you are using it as an "inelegant hack" or an integral solution to difficult and expens
... [Read Article]
Latest Ad:
WANTED Front grille/nose assembly for Massey Ferguson 1160 (also fits 1180 & 1190). Headlight-mount section. AGCO Grille 3706022M91 (supersedes 3705942M91), cover 3705494M1/M2, holders 3705501M91/3711158M92. New/NOS/good used OK. Jonesboro, AR - will pay shipping. Photo appreciated. Thanks
[More Ads]
