Re: Farmall clutch linkage
Posted by old on August 25, 2014 at 09:03:14 from (209.86.226.40):
In Reply to: Re: Farmall clutch linkage posted by Curt Cooke on August 25, 2014 at 08:18:50:
third party image
Yes you have to split the tractor to remove the clutch linkage due to the fork on the shaft where the throw out bearing is. But a cub is so small 2 guys can man handle the engine with no problem. Had this cub all apart in my shop around 10 years ago to do a throw out bear brakes etc etc
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
