OEM ballast resistors are ALWAYS between the ignition switch and the coil.
Some argue they work just as well in either location, but I suspect having them between the distributor and the coil MAY shorten point life, as that puts a series resistance into the coil-to-condenser circuit.
Today's Featured Article - Product Review: JB Weld - by Staff. JB Weld is basically an epoxy glue that does an exceptionally good job of bonding to cast iron and steel along with several other materials. As I mentioned, it is so common that I have yet to buy a tractor that did not have JB Weld used somewhere. It is sometimes used so well you can't tell its there and other times used as a sloppy quick fix. Finding where and how it can be used correctly is key to whether you are using it as an "inelegant hack" or an integral solution to difficult and expens
... [Read Article]
