Re: Farmall C Instant Load When Power Switch Turned On
Posted by John T on August 15, 2014 at 12:24:26 from (216.249.72.121):
In Reply to: Farmall C Instant Load When Power Switch Turned On posted by steamguy14 on August 15, 2014 at 11:39:38:
If its a battery powered coil distributor ignition and you turn on the switch and points are closed (as normally would be) but no other lights or loads are on, I WOULD EXPECT A CURRENT DRAW OF AROUND 4 AMPS. If a coil is drawing 8 amps the points will burn up prematurely. You dont have a 6 volt coil unballasted on a 12 volt system do you???
John T
Today's Featured Article - 50 Tips for Ford N Owners - by Bruce Haynes. Over the years of owning these three tractors, I have managed to refresh what little mechanical knowledge I had and add a little more, thanks to the wisdom and helpfulness of many fellow N owners. So, now it's my turn to share a few of the tips I've picked up. ... [Read Article]
Latest Ad: Massey Ferguson model 65 diesel tractor [More Ads]
