farmall h dip stick
Posted by transtar61 on July 28, 2014 at 18:23:42 from (75.133.150.214):
just was asking do they make a dip stick kit that can b installed in an H block so that u don't have to use the check cocks when u check the oil .Thanks .Scott
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
